Serpentor
12 months agoNeighbour
This isn't really a question, it's just FYI for Ontario (and, I assume, Quebec) customers that have Telus Pure Fibre, delivered on Bell's fibre. In Ontario, Telus has to use PPPoE. Make sure you...
Mreid153
11 months agoNeighbour
I'm in Ontario,
Did multiple factory reset, tried 10g port, LAN1 with no luck
PPoE and DHCP.
I'll tinker a bit more and get the logs when I get some time, but I'm not sure if there is anything on Telus end that has to be done first. When I spoke to tech support they said it should be working.
I appreciate your response, thank you
supermario
7 months agoFriendly Neighbour
see my post from today. There is further config required and you will need to create a VLAN with tag 35 in your own router.
