jjdinks
3 years agoFriendly Neighbour
- 3 years ago
jjdinks
It is connected to the ethernet WAN port on the T3200.
The T3200 is located upstairs and a little bit away from the ONT, so it is not directly underneath the ONT.
So it goes. ONT out on LAN1 via ethernet to the ethernet to DSL switch then upstairs theres a ethernet wall outlet that is connected to the T3200.
I assume it is this adapter that is making my T3200 not give Gigabit speeds.
Anonymous
3 years agoD you know what the model or manufacturer of the dsl to ethernet adapter?
