Alith
6 years agoOrganizer
Smart Hub computer connection light issue
Is the light on the smart hub that indicates a computer connection, supposed to be flashing or a steady on when a PC is hard wired to hub?
- 6 years ago
Steady. It flashes to indicate WPS readiness, amongst other things. The lights on the LAN ports flash to indicate connectivity.
6 years agoHero
Can you test with a different computer?
Can you test with a different Ethernet cable?
Alith
I tested with a different ethernet cable and I also tried hard wiring my laptop. Neither made a difference. When I checked the laptop network status and chose ethernet, it had an "unidentified network and no internet" message beside it.
