bskitmor
2 years agoAdvisor
TP-Link Deco AX3000 WiFi 6 Mesh System
Thinking of replacing my existing T3200M router plus 3 Arcadyan extenders with a TP-Link Mesh system. My wifi network has been showing some flakiness of late and I'm thinking it's time to move on. ...
- 2 years agoYes, should be a straight swap. I recommend duplicating the same SSID and password with the new router so you don't need to reconfigure any of your devices.
2 years agoHero
Related Content
Using a TP-Link router / AXE75, Android boxes, which settings do you change
I'm going to get the new android boxes instead of iptv boxes and fully-bridge my tp-link AXE75 from the NAH, do you guys have any settings on or off that aren't default to make it work? And, if I rem...Solved3.8KViews5Comments
