John_de
9 months agoNeighbour
TelusTV-21T Incompatibility with Samsung Frame TV?
Having serious problem trying to get TelusTV-21T to work with my home theatre system. Shaw worked fine as an input to my Marantz 7013 receiver and Samsung Frame TV (as does my DVD player, Sonos, and ...
- 8 months ago
It now does work with a new 8K cable direct into the Samsung Frame, i have not tried it through the Marantz 7013 as I have i discovered the Telus TV app for the Apple TV and that works fine so we leave the Marantz on the Apple TV input and do not bother trying to change inputs. The item on Amazon ($16) was:
Silkland 8K HDMI eARC/ARC Cable 2.1, Certified Ultra High Speed HDMI Cable 3.3ft [8K@60Hz, 4K@240Hz/144Hz/120Hz] Dolby Atmos Vision, 48Gbps, HDR, HDCP Compatible for Samsung/Vizio/SoundBar/Roku TV
Rocky3
9 months agoGuardian
There have been reports of faulty HDMI cables supplied and also using different input.
Have you tried different HDMI cables and also tried each of the inputs on TV.
Then have you confirmed any other TV with that 21-T tuner is working.
John_de
Both TV boxes work on my Sony 1080p TV. I have tried all different inputs, but am getting some new 8k HMDI cables to work that one through.
