jdanham
6 years agoOrganizer
PureFibre + OptikTV - integration issue with existing mesh wireless system
Recently got PureFibre + OptikTV installed, but because I have a significant investment in my mesh (Netgear Orbi) wireless network, my intent is to integrate the two. After the tech left I spent a co...
jdanham
Yes I already enabled that after connecting my Netgear router to LAN Port 1 on the Actiontec T3200. And like I said everything is working except audio on OptikTV, and the fact that there is one device that is not registering on the new setup suggests to me there is some `connection' between the two.
In the end, if I can't get any more insight into this we'll probably just go back to Shaw who will probably have some incentive to keep our business.
Thanks for your input though.
Regards and be safe!
Dan
sguilts
6 years agoNeighbour
If you are running your Orbi in default "Router Mode", then try doing the following:
From the Orbi web GUI, go to:
Advanced -> Setup -> WAN Setup
Then unclick the box that says "Disable IGMP Proxying".
This will allow IGMP messages to pass thru the NAT from WAN to LAN side, which is required by Optik TV
If you have already switched your Orbi to "AP Mode" then this is not required as no NAT function enabled in AP Mode.
After making the changes, you will need to restart the DVR then the STB(s) and wait for them to resync.
Note that I did not make any of the IP address reservation changes you listed out.
I have my Telus router with 192.168.1.x subnet and Orbi with 10.0.0.x subnet.
All of my devices (including DVR & STBs) are on 10.0.0.x subnet.
I also did not enable the bridge mode on port1 on Telus router.
Note that I am currently have Telus Fibre and am using Telus Arcadyan router.
However, I had same setup working previously with Actiontec T3200 on VDSL prior to updating to fibre.
- jdanham6 years agoOrganizerThanks for this! I ended up putting Orbi in AP mode, but I think performance is not as good. I even disabled the Actiontec radio to eliminate channel interference, but it seems like file copying to my NAS is a lot slower now.Anyway I'm going to try your configuration and let you know. With the way I have this set up now, I am also experiencing a significant increase in time to copy files on the wireless LAN, mostly to a Synology NAS.My DHCP reservations were done to replicate the Telus configuration on their equipment, but I also found (later) that by resetting the DVR + STBs things started working again.
