KanoeKid's avatar
KanoeKid
Organizer
6 years ago
Solved
Problems connecting Sonos SL speaker to TELUS WiFi Hub modem
Hi Community I bought a Sonos SL speaker and tried to connect it to our TELUS Wifi Hub modem through the Sonos app. I have an existing Sonos connect amp on the network. I tried connecting through W...
  • NFtoBC's avatar
    6 years ago
    The manufacturer of the most recent Telus router is Arcadyan.
    The easiest way to access the administrative interface is with an Ethernet connected computer. Using a web browser, go to website 192.168.1.254, then enter ‘admin’ and the Admin password on the hub. Under the Wi-Fi settings you should find the setting for SmartSteering. Once you turn it off, you can set it up with 2 SSID and 2 different Wi-Fi bands. You should then be able to connect the Sonos to the 2.4 GHz band.
    See this link for more info. Note thy call it ‘Smart Wi-Fi’ in the article.
