K_McIntosh
3 years agoOrganizer
OpenVPN Client-enabling firmware overwrite for NH20A?
Hey all ... I've been testing the NordVPN app on a couple of Win 7 PCs on my home LAN since NY's day ... in order to extend VPN coverage / capability to all devices on my home LAN (LG Smart TVs of di...
- 3 years ago
It's a custom gateway and I don't know of any other provider using it currently. As a result, you won't find any custom firmware for it anywhere. The other thing you also have to realize is that the NH20A is not a standard modem or router. It's the fibre Optical Network Terminal that just happens to have an ethernet only router built in. Telus has it configured so that it will work right out of the box for the extreme majority of users. The less than 1% that have needs that don't match essentially would need to add their own router between the NH20A and the rest of their network. Also if you have a fibre plan that's faster than 1 gigabit, you'd need a router that has either 2.5gbit or faster ethernet ports on it. If not you'll be capping yourself at a gigabit max. The router you linked to looks like it would have that issue.
Additionally if you have Optik TV, the set top boxes still need to be connected to the NH20A and if they're wireless, the Wifi6 Boost unit connected to the NH20A.
3 years agoIt's a custom gateway and I don't know of any other provider using it currently. As a result, you won't find any custom firmware for it anywhere. The other thing you also have to realize is that the NH20A is not a standard modem or router. It's the fibre Optical Network Terminal that just happens to have an ethernet only router built in. Telus has it configured so that it will work right out of the box for the extreme majority of users. The less than 1% that have needs that don't match essentially would need to add their own router between the NH20A and the rest of their network. Also if you have a fibre plan that's faster than 1 gigabit, you'd need a router that has either 2.5gbit or faster ethernet ports on it. If not you'll be capping yourself at a gigabit max. The router you linked to looks like it would have that issue.
- K_McIntosh3 years agoOrganizer
Nighthawk ... I'm just reviewing the Ethernet port speeds on the cited Privacy Hero WiFi 6 VPN Router ... under SPECS, I'm seeing:
Ethernet Port Type
4 Gigabit What may I have missed here ... if you don't mind elaborating please ... K Mc
- Nighthawk3 years ago
They are purposely obfuscating their specs. That's a company's lazy way of writing that there 4 x 1 gigabit ethernet ports. There is no such thing as a 4gbps NIC. I'd be very cautious about that router since they don't provide the actual full specifications for it anywhere on their site. Compared to a real router manufacturer, Privacy Hero's specs are missing a lot of detail.
... thanks Nighthawk for again providing relevant advice / observations so promptly - understood & appreciated ... I guess I'll continue to cast about for a different, suitable router (from my online reading, it looks like the better option [throughput speed-wise, anyways] would be a router supporting a VPN protocol that incorporates WireGuard [200? Mbps] rather than OpenVPN [40-60? Mbps]), then get back to this thread with an update ... K Mc
... thanks Nighthawk for stepping up so promptly and providing your sound advice ... I guess I'll have to cast about for a different, suitable router, look at the cost / benefit analysis afresh and then get back to this thread with an update on what I may be able to do about this VPN conundrum ... K Mc
