Bearsfan
3 months agoOrganizer
Not able to use Alexa with Telus Home Assistant
The other day I went to turn on one of my Telus digital boxes via Alexa and it responded by saying sorry XXXXTV is not responding. I tried the other two cable boxes via Alexa and they too would not r...
- 29 days ago
An update: We identified the issue late last week and worked with our vendor to resolve the Skills issue. Our testing showed it was working fine as of Friday. Can you confirm that it is? If not, please disable it then re-enable it and try again.
Thank you so much for your patience with us!tgrosse tgrosse ecoulter Marie17 ketev48046
Edit: Marked as Solution for visbility
jkl67890
2 months agoFriendly Neighbour
Hi,
I have not been able to control the TV using Amazon Alexa since the last update. The best able to his turn the optic box on and off. It will not change channels, show the menu, or anything else.
Is there a solution?
