DragonDal
4 years agoNeighbour
Not able to enjoy 1.5gb speed internet upgrade
I recently upgraded my internet 1.5gb speed. However it most unfortunate that I use wired connection to my pc, Telus recent hardware does not support anything faster than 1gb wired. Seems like waste,...
- 4 years ago
DragonDal Wrote: Telus wifi hub which is that has 1gb wan port and 4x 1gb lan ports and my pc has a 2 5gb nic I would get 1 5gb speed correct.
I think the simple answer is no. if the Telus hub as you have referred to it, has a 1Gbps WAN port and 4 1Gbps LAN ports, the best you will see is 1Gbps speed throughput on the wireline.
Now if you have Telus equipment capable of either 2.5Gbps WAN and LAN or in the example of the Arcadyan NH20A Router having a fibre WAN connection, and the Capability of 10Gbps LAN port you see the capability of full 1.0Gbps, 1.5Gbps, right up to the 2.5Gbps speeds currently offered by Telus.
DrPacman
4 years agoRockstar
DragonDal
Hi Dr,
Yeah exactly what I thought hence my original post after contacting Telus support and was told that they do not have any hardware that supports anything highrr than 1gb . I have the Arcadyan WiFi hub. So now i am confused . I guess will have to contact them again about upgrading to the Arcadyan NH20A Router having a fibre WAN connection, and the Capability of 10Gbps LAN port
- FuzzyLogic4 years ago
While any one device might not exceed 1GB if you use multiple devices at the same time you could potentially reach the 1.5GB speed advertised.
