BobArthur
3 years agoLeader
NHL Hub Channel Not Working Correctly
The NHL Hub channel ( channel 910 in Vancouver ) has not been working correctly since the NHL returned from the All-Star break. For example - right now all 3 of the games on the schedule tonight just...
2 years agoI'm in Edmonton and it works fine for me. It's got current stats and schedules. Which teams are you following? Which set model of top box are you using?
Eleonoragodwin
2 years agoNeighbour
It has not worked for over two months.i thought it might be the tv , unplugged it and reset the box etc , nothing . Called Telus and reported it to a tech , he did a check while I was on the phone with him .he said that it was a problem with the provider . I have since made 4-5 reports on here and it is still not addressed.. I follow the same team as always , no changes on my end , but it always show the games <but not the scores/updates.
