Dan_in_distress
6 years agoNeighbour
More wired connections required
HI,
I just connected to PureFibre, and my new telus WiFi Hub is maxxed out for Cat 6 connections. What is the best way to connect more hard-wired connections throughout my house? We already use one port to a router to increase reach for wireless devices. I have three or four more rooms to connect wires from.
I am guessing a router, but I also see references online to an ethernet switch? Are there better options?
Thanks!
- RonAKARockstar
I was short of hardwired ethernet ports on my T3200M modem when they installed it. The tech gave me a 5 port ZyXEL switch. That was enough. There are larger switches that you can buy. See these for examples:
https://www.memoryexpress.com/Category/Switches?Search=ethernet+switch
- FuzzyLogic
As mentioned a switch is probably all you need.
This may help with your planning:
What's the Difference Between a Hub, a Switch, and a Router? - Ask Leo!
- xrayHero
Unmanaged switches are cheap and available everywhere in an assortment of port capacities. When you ask for a "better" option what you mean by that?
