MariuszStepien
3 years agoNeighbour
I upgraded to PureFibre 1.5 GB but speed remains 1GB
It is a simple set up, one hard wired computer and Cat6 cable. Telus support not very helpful. I'm confused - did all the restarts etc... Any suggestions ?
- 3 years ago
MariuszStepien Wrote: It is a simple set up, one hard wired computer and Cat6 cable.
A number of caveats on installing 1.5Gbps internet:
1. Telus says that the 1.5Gbps is cumulative i.e you'll see a total of 1.5Gbps download amongst all your devices. Not necessarily on a single device.
2. Some of us have created systems that can, and do support the total bandwidth on a single connection.
3. Undertaking the creation that supports a single connection is not for the faint of heart. You require additional hardware, and some knowledge to obtain these speeds.
My suggestion would be to have a gander at the following YouTube videos' for an idea of what may be involved with what you want to achieve.... Cheers...
https://www.youtube.com/watch?v=5WWO_4p4UP0&list=RDLV2P6Miz-wRcw&index=2
https://www.youtube.com/watch?v=gzk69kHLu1o
MariuszStepien
My Ethernet - 10/100/1000BASE-T Gigabit Ethernet (RJ-45 connector) - which should support connection up to 10GB
Jimmyinbc
3 years agoFriendly Neighbour
This 10/100/1000BASE-T Gigabit Ethernet speed is Max 1Gb ( most new motherboard support 2.5G also the new Wi-Fi 6 card can reach 2.4G speed...
- giantbrownguy3 years agoRockstar
I also read in another forum, on some of the Telus modems, one port is available for 1.5 GBPS, but the rest are limited to 1 GBPS. Once you have the right set up, I would test it.
- DrPacman3 years agoRockstar
The newer ONT/Modems have a 10Gbps port that can support a direct connection, or be placed into bridged mode to connect additions user supplied equipment. This would allow for an entire networks ability to connect at 1.5Gbps or faster connections. Cheers
