MariuszStepien's avatar
3 years ago
Solved
I upgraded to PureFibre 1.5 GB but speed remains 1GB
It is a simple set up, one hard wired computer and Cat6 cable. Telus support not very helpful. I'm confused - did all the restarts etc... Any suggestions ?
  • DrPacman's avatar
    3 years ago
    MariuszStepien Wrote: It is a simple set up, one hard wired computer and Cat6 cable.
    A number of caveats on installing 1.5Gbps internet:
    1. Telus says that the 1.5Gbps is cumulative i.e you'll see a total of 1.5Gbps download amongst all your devices. Not necessarily on a single device.
    2. Some of us have created systems that can, and do support the total bandwidth on a single connection.
    3. Undertaking the creation that supports a single connection is not for the faint of heart. You require additional hardware, and some knowledge to obtain these speeds.
    My suggestion would be to have a gander at the following YouTube videos' for an idea of what may be involved with what you want to achieve.... Cheers...
    https://www.youtube.com/watch?v=5WWO_4p4UP0&list=RDLV2P6Miz-wRcw&index=2
    https://www.youtube.com/watch?v=gzk69kHLu1o
