DantasticNeighbour2 years agoI bought a mini camera for a common area, but it will not connect to a 5g What do i do on my Hub to get access to a 2.4ghz network? Thank you in advance
A-BCommunity Manager2 years agoI'm not 100% sure it has the capability to switch over to that, but you can call our SmartHome team directly at 1-855-255-8828 so they can confirm!
Related ContentCannot Connect Cameras After Internet Upgrade We just got an upgraded internet via Cogeco. Reconnecting our cameras to the new router isn't working- I've factory reset the doorbell camera and it keeps failing to verify the connection. Solved[Megathread]: TELUS Connect I have had issues with this app since I started using it ages ago. It's glitchy and almost completely useless. It boasts such amazing features - schedules, device-blocking, content-blocking and...SolvedConnect App - Not connected to Home Network The Connect App no longer works. It says, "You need to be on your home Wi-Fi and enter your admin password to proceed. Please ensure you're connected to your Wi-Fi and reopen the app to try again" ...SolvedHas Anyone Connected Lorex Security Cameras I want to install a Lorex IP NVR (Network Video Recorder) security camera system and the Lorex rep advised that the NVR needs to be connected directly to a router and not through a switch. I've tried...SolvedWireless Doorbell Camera? Is the doorbell camera wireless? Specifically, does it run on a battery or must it be hardwired to the house. My house currently does not have a doorbell, so if it must be hardwired, does Telus do th...Solved
Recent DiscussionsOptik TV Remote control of Onkyo volumeCanadian film channelInternet and phone and TV outage192.168.1.254 login.Need separate isolated network for work purposes
