Vancouver-condo
2 years agoOrganizer
Fibre along with either Coaxial or Ethernet cable
I would appreciate advice. We are renovating a condo in downtown Vancouver that had fibre installed a couple of years ago. The condo was built in 1982, and has a suspended ceiling with 15 inches of ...
Vancouver-condo
Here is the inside. Also the second picture shows the Ethernet cable.... it hooks through the wall then is deconstructed and hooks into the phone jack craziness ???
Any help appreciated!
polecat
2 years agoAll-Star
Now i see -- fibre panel is good the rest is junk . not enough wires in tel cable to do internet from ont. The fibre will hook to the ont ( Needs 120 volt ) run cate 5 above the tbar to your locations. You can have your router modem with wifi fed with the cate5. Possible feed the cate5 from inside the wall to above the tbar ceiling so it is hidden. I would get an electrician to do this if you don't know how. Being a condo your wifi coverage should be good even with some concrete walls . The tv's can use the wifi to feed them. Good luck Polecat
