klocsin
5 years agoNeighbour
Ethernet Switch not working with MoCa adapter
I wanted to upgrade my work-from-home office and gaming setup and by hardwiring both my MacBook and PS5 instead of using WiFi. I have almost no experience with Network configurations/troubleshooting,...
klocsin
NFtoBC I tried connecting my PS5 directly to the MoCa adapter and now it won’t work. Getting the same IP address notification.
It’s worth noting that this MoCa adapter was being used in an adjacent room before I moved it to where it is now. Would it matter that I changed rooms from where Telus originally had it? It’s still going through a coax socket.
5 years agoHero
klocsin it wasn't clear in your initial post that you changed rooms on the second floor. I assumed you were in the same room and just added a switch.
I agree with NFtoBC that it's likely the coax in the 2nd room isn't connect to the T3200M which would be the root cause of the problem.
