deutschophile
5 years agoNeighbour
Desktop does not reconnect to wifi when waking from sleep mode
I have an iMac desktop and the T3200M router that was just installed this week. The internet runs perfectly but I noticed when the computer goes to sleep and wakes up it doesn’t automatically reconnec...
5 years agoHero
When you have this issue can you hit the router web page to confirm that you indeed have a WiFi connection? I find it hard to believe that the T3200M would care whether the client is a Mac or not after getting a WiFi connection. It possible the WiFi status isn't correct and you don't actually have a connection.
deutschophile
You are right I can’t get onto the router page either
- xray5 years agoHero
So the issue is the Mac doesn't reconnect to WiFi coming out of sleep and lies about it.
It's not clear whether it tries and can't or doesn't try at all.
- deutschophile5 years agoNeighbour
So I bridged the T3200M to my airport extreme and changed nothing else. My computer reconnects to wifi fine when waking. It is definitely something to do with the router.
