starsfan9
6 years agoNeighbour
Chromecasts Not Working on Telus Wifi Hub
Has anyone had issues with chromecasts on a Telus wifi hub? We recently switched to Telus and ever since the chromecasts are intermittent at best with their connectivity. When streaming music, the con...
EdmUser
6 years agoFriendly Neighbour
I have this issue on the wi-fi hub. I've never seen a solution for it on here. I just deal with intermittent chromecast connectivity. It sucks.
People always suggest changing settings like disabling band-steering which work on older routers they have but that as far as I can tell (with chats with TELUS) you can't do with the wi-fi hub.
Other solutions such as hard wiring I guess work but don't really count as fixes to me.
The wi-fi hub does have a passthrough option which means that you could use your own better router, but you would need to theoretically hard wire your optic TVs first and telus wasn't able to confirm that hardwired optics to the router in its passthrough mode would work. I don't think they have (or had).
