starsfan9
5 years agoNeighbour
Chromecasts Not Working on Telus Wifi Hub
Has anyone had issues with chromecasts on a Telus wifi hub? We recently switched to Telus and ever since the chromecasts are intermittent at best with their connectivity. When streaming music, the con...
5 years agoHero
Try turning Smart Steering off if you have it on. It might be the devices flip-flopping between the 2.4 and 5 GHz WiFi. With Smart Steering off it forces the devices to stay on whatever WiFi you set it up on.
- starsfan95 years agoNeighbourI don't seem to have this setting on the app or in the admin page, similar to the other poster. The issue is still persisting. The devices show up, then disappear at random.
- DavidL5 years agoFriendly Neighbour
To turn off Smart Steering - do this:
1. Make sure you are on the Telus wifi on your laptop/ipad.
2. After connecting to the router, open a browser and go to: http://192.168.1.254
3. Login with the user ID that's on the label on the T3200 Router (and not the extender). This will be different than your wireless access code.
4. click on "Wireless Setup"
5. Disable Smart Steering and try again
- Spud3875 years agoOrganizerDavid, This post is about the new Telus Wi-Fi Hub not the Actiontec T3200 or the mesh access points. It is very simple to turn off smart steering on the t3200 but I spoke to telus support yesterday and they confirmed that you cannot turn off smart steering on their new Wi-Fi Hub router
I am encountering the same issue with my Google devices. I do not see the option to turn off Smart Steering in the App or the Admin page.
