NewfieRocket
3 years agoNeighbour
1.5 GB Fibre and ONT
I recently upgraded from 1.0 to 1.5 GB Fibre. I have the the acatel G-240 G-A ONT. From what I read on the inter webs is that Data Port 1 is only a 10/100/1000 Port. Can anyone confirm or deny t...
- 3 years agoYes, right now your 1.5G is just bandwidth. You need to be upgraded to a newer ONT and on top of that Telus needs to check if your line is connected to equipment that supports over 1G on their end. Not all neighborhoods have faster speed equipment readily available, so even with a NAH router and new ONT you could be stuck with just extra bandwidth instead of actual speed. Best way is to call fiber customer service and ask for a ONT upgrade since you want faster speed not just more bandwidth, but if the equipment is not available for your street the new ONT won't work.
DrPacman
3 years agoRockstar
NewfieRocket Wrote: Data Port 1 is only a 10/100/1000 Port.
Indeed after reading some of the online literature and Specs for this device, it seems as it indeed has 1Gbps ports.
I would contact TELUS support to discuss a hardware u[grade to enable support for your 1.5Gbps service. Cheers...
