coolofficialss's avatar
coolofficialss
Friendly Neighbour
2 years ago
Solved
HELP IMMIDIATLY
i need help i have telus sim card but its not getting any signal i am from karachi pakistan i am sending you sim pic please help me with my problem My contact number is <Personal Info removed by Mo...
  • dru's avatar
    dru
    2 years ago
    coolofficialss You have images sitting in our moderation queue but for your protection, we've deleted them. The SIM card number is visible and is considered private information.
    As for your issue - if you're roaming with the SIM card inserted into your device, try manually selecting each carrier to see if one works for you.
