rain
5 months agoNeighbour
Asking how to get PIN2 code for Fixed Dialing Numbers (FDN) Issue
I'd like to know my PIN2 code so I can disable the Fixed Dialing Numbers (FDN) feature. I asked it by phone, but it seems the person is not familier with this subject. Should I go to Telus store, will they can help me?
1 Reply
- Nighthawk
A brief bit of Googling seems to indicate the default may be 1234, though that is from an old post from Public Mobile, which Telus owns. That may or may not work. Not all SIM cards support FDN. I highly doubt the local Telus store will be able to do anything as they are primarily sales, not support.
Telus does not advertise whether or not their SIM cards support FDN. If by some unlikely chance you have one that supports FDN/PIN2, FDN is not typically a feature that is enabled by default on compatible phones. Don't forget the PIN2 code as I doubt Telus will provide a PUK2 code to unlock FDN on the SIM.
