June
June
Yes, a booster should improve the situation. It's the distance between the router/booster and the Optik box that's important. The PVR location is irrelevant as long as the PVR connection is good.
A wired connection (Ethernet or MoCA) would be more reliable if available. All my Optik boxes are wired and I never have speed or congestion issues.
June
June
June
