Telus TV + on Android TV problems with live TV
Dococ
Friendly Neighbour
I have a sony A80J tv which has android TV. I tried downloading the telus tv + app. Video on demand plays fine, and if I go to the program guide a chose to play a program from the beginning it works fine. However, if I try to play a program that's currently broadcasting I just get a black screen. It happens with any channel. Essentially can't stream live tv.
App version 1.5.7.103
MW version 660701
Android TV OS version 10
Kernel version 4.19.75
Android TV OS build 10 QTG3.200305.006.S252
6670701 release-keys
There's already an existing discussion on this: https://forum.telus.com/t5/Pik-TV/Live-TV-broken-for-TV-on-AndroidTV-Sony-Bravia/td-p/134079
1 REPLY 1
