February
My question is this.
I am currently travelling in Asia fro the month of Feb and Mar. before I left I contacted Telus about Easyroam, and they said that I did not need to worry about roaming charges when I am connected to wifi. I have been careful to turn off my Cellular Data whenever I dd not have access to wifi, and yet I got a roaming bill fro $300 for one month ($15/ day, the maximum). I was not notified that this was happening get the time. When I finally contacted Telus Support online I was told that sometimes roaming charges do apply when you have wifi, if the connection is poor. But the connection was always strong the hotels where I was staying. The solution, I was told was to turn off cellular data and Wifi Assist and leave it off all the the time. I was not told this when I talked to Telus before I left.So much fro Easyroam. There i nothing 'easy' about it. So, my question is this: where do I raise this complaint? It is not all clear from their website. Needless to say, I will be quitting Telus for another service when I return home. In the meantime , I wanted to alert other users to this problem with Easyroam. I will also be contacting CBC Marketplace about this.
March
Hi @arthbull
Sorry to hear about what happened with the roaming fees. When you travel overseas and you block your data is not the only feature related to Easy Roam. I suggest you visit this link to find out a little bit more. https://bit.ly/41z39uJ If you want to place a complaint you would have to contact our care team using this number while you're overseas
March
- last edited
June
by
dru
March
Hi @arthbull, what I meant to say is that data is not the only thing that will charge the Easy Roam.
March - last edited March
This is a known problem with Easy Roam and similar features from other carriers. It's highly dependent on how your particular phone manages the data settings and the phone's interaction with the mobile connections. Some phones ignore the data roaming setting for certain things and at certain times and will use a small amount of data. That's enough to trigger Easy Roam.
https://forum.telus.com/t5/Mobility-Services/Easy-Roam-triggered-without-any-usage/m-p/95667
The only reliable way to disable data usage is to use airplane mode and then turn on just WiFi.
https://forum.telus.com/t5/Mobility/Roaming-with-Easy-Roam/ta-p/132916
March
March
HI xray,
Sorry...that thank you was meant for you.
My issue with Telus is that they didn't inform me of this, but instead said categorically, on the phone and on their website that "Data usage does not apply when using Wi-Fi or if data roaming is turned off.". If you know that this is not necessarily the case it seems highly unlikely that they don't know this too. In other words, it is downright misleading. I want to give them the benefit of the doubt on this, but on the face of it, problematic.
Arthur
March
@arthbull wrote:HI xray,
No worries, I knew what you meant.
I don't think it's strictly misleading because that's how it's supposed to work. It's definitely incomplete though because like many tech things the implementation is deficient and there are factors outside of TELUS's control like the device OS behavior and the roaming tower behavior.
March
None of these responses addressed the fact that Telus said unequivocally, both on the phone and on their website, "Data usage does not apply when using Wi-Fi or if data roaming is turned off". and this turned out to be not true.
March
When you were away did you make any phone calls or reply to any text messages at all as they would also trigger an Easy Roam charge.
March
I didn't make any calls or send any texts, as far as I can remember.
March
March
- last edited
June
by
dru
