05-02-2020 02:01 PM
Hi I have a frustrating problem.
ALL incoming phone calls go directly to my inbox voice mail. The phone does not ring.
This was happening on my much preferred Windows 10 phone and found no resolve for the no ring problem on that phone.
Thinking it was a hardware problem on my Windows 10 phone I purchased a used Samsung S5.
Much to my surprise my new Samsung is not ringing with incoming calls, instead ALL phone all calls are going directly to my voicemail with no ring,
Any ideas?
Bad sim card causing a no ring?
Telus network problem?
I have a new sim card but Telus SWITCH PHONE online is down still and Telus is not answering phones still.
Any help would be so much appreciated! I really need to answer my phone calls.
05-02-2020 03:31 PM
UPDATE
On Telus chat support the technician checked the network and come to the conclusion some kind of code was missing which prevented calls from going directly to my phone but going directly to voicemail.
The code was removed due to my pay and talk account feature expiring and not being recharged right away.
His advice was to not allow the expiration of my plan.
Thanks!!
05-02-2020 02:13 PM
Where did the S5 come from? Which provider was it from originally? Is it unlocked?
05-02-2020 02:25 PM
Hi Nighthawk
I purchased it online, the seller claimed it was locked to Telus After I reset it to factory I found a Telus feature app preinstalled, so to me that confirmed it was a Telus phone.
My plan is a pre payed plan,
05-02-2020 03:31 PM
UPDATE
Thanks!!
