Monday
Just had telus fibre 50 installed , my speed doesnt seem that high at around 9Mbps and 18 Mbps , download and upload respectively . Any ideas on why or is this normal?
Monday
How are you measuring your speeds? If WiFi speeds can vary widely depending on many factors. Use a wired connection to measure your speed and depending on the router it may have a built in speed test that would be recommended.
