11-05-2020 08:23 PM
Being blocked access because username is offensive. Used polecat from the day the neighbourhood went on line. Whats up. Banned all day today.
11-06-2020 11:40 AM
Hi everyone, it's definitely not you - it's affecting admin/mods as well.
We're working with our vendors to root out the issues. It might take some time as the root cause is proving to be elusive but we'll give the all clear once I have confirmation we're good to go.
Thanks so much for your patience!
11-05-2020 08:31 PM
I've been dealing with the connection rejected error for a few days and now this.
11-05-2020 10:55 PM - edited 11-05-2020 11:04 PM
@polecat The forum was having issues last few days. Telus acknowledged the problem and was looking for the root cause. “Banned” and connection request errors, was one of the few issue(s). You weren’t banned just a glitch in the software. If you tried to log in enough times, you could eventually sign in/post. Seems to have been fixed or at least stabilized tonight.
@xray The picture uploading has been a problem for a while.
11-06-2020 01:00 AM
11-06-2020 11:40 AM
11-10-2020 01:23 PM
I wasn't able to login to the forums for the last few days. It appears to be working now. Any update on the cause/resolution?
11-10-2020 02:44 PM
I found that clearing all the cookies for this site helped.
11-11-2020 09:16 PM
This is a test message. I composed a response to a question here the other day, and then lost it all when I tried to post it and I got a message saying I was banned. Have not bothered to come back since.
11-12-2020 11:07 AM
I've experienced that as well. Sometimes the reply actually goes through eventhough you get that error. You should check for your reply before posting another one.
I've also got into the habit of copying any long reply to the clipboard before clicking on Post just in case.
01-19-2021
12:14 PM
- last edited on
01-19-2021
12:15 PM
by
dru
I am also having this problem in Chrome and Firefox. I added https://forum.telus.com to my trusted list in Chrome and so far it's working.
01-19-2021 12:19 PM
That above link is wrong with current version of Chrome. You need to eventually get to Internet Properties somehow. What I did in Windows 10 is go to Control Panel > Network and Internet > Internet Options > Security (tab) > Trusted (icon)
