12-21-2023 11:54 PM
Hello!
I need to remove the NAH Wall plate from the wall. I will not be moving the NAH but just need to have some wall repairs and painting done.
I have removed the front cover. I have not yet removed tha main unit with the grills. I have not yet removed the wall plate.
Can anyone here know how to remove it safely?
Thanks in advance!
01-22-2024 11:50 PM
I had the help of a technician. He used a screwdriver to pry something a latch that can be accessed in one of the gaps underneath the plate.
01-22-2024 01:35 PM
Hello. Just following up on this. Were you able to get this plate removed safely?
01-22-2024 11:50 PM
