dnord
1 year agoFriendly Neighbour
Using old 3200M as second wifi network.
dnord
I just upgraded to 1G fibre - works great. I need to setup a second wifi network in the home.
I have an old 3200M modem/router from old subscription. Is there a way to use the old 3200M as just a wifi router, not a modem?
I have tried to connect it to a port on the square fibre box, as well as port 1 on the white wifi cylinder. I've turned bridging on for everything but the 3200M is not getting an internet connection.
I have tried putting a gigabit switch from square fibre box to both cylinder router and 3200M. The cylinder works, 3200M does not.
Is there settings I can adjust to turn off the modem part of the 3200M and just use the WAN port and wifi capability?
My end goal of a second wifi network - is this even possible? Is it much easier to accomplish with a new wifi router?
Thanks for your Help
- Nighthawk1 year ago
Are you just looking to set up a guest network, another network that shares your main one, or a completely separate and isolated wifi network that can't see your existing devices?
Which square fibre box do you have? There are two different ones. Do you see a brand or model on it? Does it have a coax port on it also? There are also two white cylinder shaped devices Telus offers as well. There's the Wifi Hub and the Boost 6 wifi access point (not a router).
Left is the Network Access Hub. Right is an ONT (no coax port).
Left is the Wifi Hub. Right is the Boost Wifi 6 AP.
Depending on the hardware you have and what network you're trying to set up there are some options for the T3200.
The T3200M will not be able to function as a simple wifi access point as there is no way to shut off DHCP. The Boost Wifi 6 from Telus would be a better option for that, or if you wanted to set up just a generic wifi access point, that's an option also. If you wanted to set up a physically separate network, the T3200 can be used for that as a router but there will be an extra step needed depending on which hardware above you have.
Related Content
- 7.8KViews19Comments
