jjdinks
2 years agoFriendly Neighbour
- 2 years ago
Anonymous
2 years agoYou would probably need a separate phone line from the ont modem which has a RJ11 phone jack for the phone line which telus technicians from the fibre team can help with re connecting between the T3200 m and the ont modem
Also a separate line for ethernet on data 1 or lan 1 from the ont modem to the T3200 modem which you can install yourself or you would have to ask a it company or pc or network repair technicians that install network wiring or structural cabling of ethernet , coaxial or phone lines.
jjdinks
Thanks,
The fibre was first installed 2-years ago I think. It was when Telus was rolling out fibre in Edmonton.
I'm pretty sure my home phone line will be okay right? I just need to get rid of that adapter and run a straight ethernet to ethernet connection from the T3200M and ONT.
Would Telus be able to fish this ethernet to ethernet port for me?
- Anonymous2 years ago
- Nighthawk2 years ago
- jjdinks2 years agoFriendly NeighbourNo, I could probably find some videos online or just use the existing DSL run to the T3200 and use that to fish the new ethernet cable in.
As for my home phone, I am pretty sure it is not on fiber so its not being connected from the ONT. I believe this is true because on the MyTelus website I am offered the option to switch the home line to fiber.- Anonymous2 years ago
Your home phone line is on a separate line, on the existing copper line.
The ethernet is on a separate line, then a ethernet cable run between the ont modem and the adsl, ethernet adapter.
