Meme_stealer
6 years agoOrganizer
Lan ports and wifi on modem are not working
The only port working on my modem is the wan port and wifi isnt working either
6 years agoHave you:
1. restarted th router?
2. Reset the router using a pin in the hole?
Meme_stealer
yea i already tried that didnt work
- Nighthawk6 years ago
Which modem do you have?
- Meme_stealer6 years agoOrganizer
t3200m and the wifi is working now but all lan ports still dont work
i acctuly fixed it by plugging the wan in a router so it is working fine now thanks for the help
