minchadw
1 year agoFriendly Neighbour
How should I configure home network with switches and nests.
I have an unmanaged switch (d-link DGS-1016c) in a data closet supporting wired connections throughout my house. Since installing the switch, my Optik TV ceases to work (drops network connect in abou...
- 1 year ago
Your previous setup of ONT > T3200 > Optik Box is no longer possible at your new place? The T3200 has multiple LAN ports on it so if there's a dedicated ethernet run to where the Optik box is, plug that directly to the T3200. You can have the Eero and your switch plugged into another of the LAN ports on the T3200.
minchadw
Interesting re eero. My current setup has it before the switch which its documentation suggests, but you think this is a problem re my Optik box...h'mmm
