nhcho
2 years agoNeighbour
Ethernet wall ports not working
I just moved into a new apartment with a telus modem pre-installed that has 4 ethernet wall ports and 4 corresponding ethernet cables that lead to the telux box. When I connect all 4 cables into the ...
Norm3
2 years agoOrganizer
You said "new apartment". Is it new as in no one has ever lived in it? If so the ethernet wiring was probably installed and terminated by the electricians and not a data cabling specialist. Electricians think they know everything about wiring, but in actual fact they don't. You'll have to get someone in with a data tester to test and fix the obviously mis-wired jacks.
