Grimmt
2 years agoAmbassador
Audio Sync Issues on Optik TV - TelusTV-21T
I have the Optik TV TelusTV-21T android box with HDMI connected directly to an LG OLED 65" TV (CX).
I have exhausted adjusting all sound settings on the TV and on the Telus Optik TV box and sti...
- 2 years ago
Found a work-around.
I had tried all audio option combinations on the LG and TelusTV-21T on my HDMI2 port.
However Consoul mentioned trying a different port and thanks for this, as I moved to HDMI1 port and video/audio sync is now good.HDMI2 on an LG OLED CX is the only port that provides ARC/eARC support (although I have it disabled).
I've used HDMI2 since I bought the TV and it worked perfectly on Shaw and has had issues since moving to Telus. It's had acceptable audio drift up until the last few updates - now it's crazy bad.Glad I found a work-around by using a non-ARC/eARC HDMI port (HDMI1).
Rocky3
2 years agoGuardian
No you are not alone.
What has worked for me is turn off or on surround sound. The issue was posted before and it depends on the broadcast which switch works
