Will Optik TV work over my 4KM Point-to-Point Link (network map included)
Reply
Highlighted
We currently have Coast Cable (Eastlink) for broadband Internet, and are planning on adding TV to our plan. However, their TV packages kind of suck, so I'm considering switching to Telus for TV (non-4K) and Internet.
If I remove the Coast Cable modem, can I add a Telus broadband modem and a Telus HD TV box (not 4K or PVR) into my current network as shown below?
Highlighted
CPU Alum
CPU Alum
How fast is this Point-to-Point link?
Highlighted
I'm also curious if a point to point link will properly support multicast needed for Optik TV to work, same with the router on the house end. Also if the point to point link is private and dedicated to the one residence.
Now if it was Pik TV, there would be far fewer possible compatibility issues but it does have a more limited channel selection than Optik.
Highlighted
I ran a ping test and speed test from the shore antenna to the house antenna here on the island. Tests were done during the "slowest" part of the day (where the sun causes a lot of reflection off the water). What do you think?
Highlighted
Can you test by purchasing Eastlink's product for a trial? Should be a low cost option to buy then cancel if it does not work.
Highlighted
Advocate
I think Optik TV in the worst case is ~5-10 mbps per channel (with exception of 4K)
You should be good if you can sustain that plus a few megabits to spare
Highlighted
Advocate
Curious, does the fixed wireless equipment do double NAT? If so you might need to remove it for Optik TV to work properly.
Highlighted
Resident
Ubiquiti Rocket M5 support IPv6 and multicast, so they should, in theory, support OptikTV. You'll need to make sure your switches at the other end also support those.
If you can swap those M5s out for AirFibre radios, then you'll be golden. The AFs are straight layer 2 bridges; anything coming into the radio at one end, comes out the radio at the other end unchanged. It works no different from a long fibre optic cable.
Telus Internet --> Ont terminal --> AirFibre --> AirFibre --> Telus router --> normal in-home setup to the boxes.
Highlighted
Resident
@JTL: they can be configured for NAT, but they're usually configured in a bridge setup between the wired and wireless NICs. The M5s are layer 2 devices allowing for vlans for end-to-end isolation. But they act as switches, processing the packets as the come in, so all the normal multicast issues with separating the TV boxes from the ONT/router or using a non-Telus router would apply.
