Data Usage Spikes on Pure Fibre
D18
Connector
Just wondering if anyone else has experienced data usage spikes in the last couple of months. My wife and I normally use about 6 Gb/day. Three days last month there were spikes of over 300 Gb.
When the last one occurred I checked the modem's service log and there was no outside device that connected to the network when the spike occurred. I've also checked the computers for virus/spyware and they are all clean.
Telus has swapped out the modem thinking that may have been the issue. I'm curious to know if anyone else has had this experience.
3 REPLIES 3
There were parallel discussions a year or so ago. You could search for them to follow the discussion.
Yes, I was aware of the previous discussions, but was just wondering if there were any recent occurrences and what the cause was determined to be.
I'm not on fibre but I did have a spike when my Windows 10 PC downloaded a very large update, failed to install it, then tried to repeat the process a few dozen or more times or so before I caught it. It used a large amount of data for that. Most usage spikes will be something on the user's end.
