Won't work with PureFiber?
uno
After waiting for my order for a week, called customers service for the order status, only to find out that this won't work with Purefiber 150.
Suggested that I downgrade to 50mbps speed. smh.
4 REPLIES 4
PBA
Coach
Errrrr... I'm on Pure Fibre Internet 150 and I'm using Pik just fine.
I did have some weird message about it not being supported when I tried to enrol last month, but they told me that was an error on the web sign-up.
uno
They won't process the order unless I downgrade to 50/10.
That doesn't sound logical... It'll work on anything 15mbps or higher. They should have some way to get it put in.
@dru @A_Kron - any ideas?
Danger
Advocate
Don't know why they are giving you a hard time, I just got Pik last week and have fiber 150. I did however go to London Drugs and buy the Pik box directly.
