PIK TV Guide
Edinrb
I’ve had PIK for 3 months now and so far the service has worked well.
I would like to offer a suggestion re: the guide - I would like to be able to hide channels I don’t watch (example, the French language channels) so that the guide is as compact as possible, showing only what I watch and what I want to scroll through.
Is there is a way to do this now, and if not are there any plans to add this functionality?
WestCoasterBC
@rmfont @Edinrb You can make your suggestion(s) be heard here.
2 REPLIES 2
rmfont
Organizer
Great idea!  Hopefully someone at Telus is reading through these suggestions and sending it up the channel.
WestCoasterBC
