09-04-2020 01:10 AM
I have a:
4k wireless digital box plugged into a
Samsung pc monitor
via HDMI.
My Optix TV is fine BUT
if I open my monitor again...
it's snowy...
It only works once I manually restart the Optik TV from the device (NOT REMOTE). That takes 2-3 minutes.
Any way to make the startup experience more efficiency. Kinda stupid I have to run again the device upon opening the monitor.
09-04-2020 01:26 AM
Have you tried the wireless box connected to an actual TV instead of a PC monitor? The PC monitor will behave a bit differently than a TV.
09-04-2020 02:00 AM
Not yet. I'll have to get/borrow a regular TV first in my suite.
Aside, will displayport make a difference instead of HDMI?
09-04-2020 12:26 PM
Have you tried unplugging the HDMI cable after turning on the monitor and plugging it back in?
HDMI is a mess as far as compatibility between source, display and cabling. Might be worth trying a different cable as well.
