Volume on remote
Reply
nancysav
Pair volume from hitachi remote to TELUS remote
If you have a Hitachi TV, you will need to program the Optik remote to work with it. The remote can not pair with another. Use the following link to locate your remote code and instructions on how to program the Optik remote: https://www.telus.com/en/bc/support/article/program-slimline-remote-2
