Slimline 2 Remote won't power on/off both box and TV
SUBZERO-08
Hi there, I have been trying to configure my remote to power on and off both the TV and Optik TV Box at the same time. I am using a Sony Bravia X900H TV and have configured the remote using code 1466.
Afterwards I also tried setting the remote to use code 0007 to enable this feature, but it only turns on/off just the Optik Box, rather than the TV as well.
Does anyone know how I can get this feature to work correctly? Thanks!
FuzzyLogic
You need to ensure the individual power buttons (TV and Optik) work correctly for powering on/off these devices. Once that works you should then be able to use the power sync feature.
Here is the Telus documentation on getting this to work:
telus.com/en/bc/support/article/program-slimline-remote-2
Sony remote codes:
1465 1466 1164 1376 1179 1467 1168 1464 1375 1468 1165 1931 1469 1322 1291 1167
1 REPLY 1
FuzzyLogic
Sony remote codes:
