Samsung (Optik) TV connecting to Samsung Sound Bar (T40M)
hydrangea
Unable to get sound bar to pair with TV. Currently have digital optic cable going from sound bar to TV.
Suggestions?  Total geek here.
1 REPLY 1
I'm not sure if the newer Samsung TVs are similar to my current older one but I had to go into the settings on the TV itself and tell it to use just the external speakers instead of the built-in ones. Never tried with a TOSLINK connection (optical) but it may work the same.
