Remote PVR Management?
gmosley
Doesn't seem like it's possible, but, maybe I'm missing something.
Can I delete recordings from my home PVR thru the Optik TV app remotely?
5 REPLIES 5
No. You can only set new recordings at this time.
Hero
Yes you can. In the app click on the PVR tab. At the bottom there should be Manage All Recordings. Select the recording and there will be a trashcan icon to delete the recording.
I'd show you but the app blocks the ability to take screen captures which is quite annoying.
@xray - My bad, you're right. I had no problems with screenshots for the app:
@Nighthawk, the blocking of screen captures may be an Android thing, I believe you are using an iPhone.
I don't see your images in your post however? I just see 3 squares where they should be
Yes, I am using the iOS version of the app so that could be the difference.
The images load fine for me but only if logged in to my account. Not sure why they aren't showing up properly... The image I see if logged out is some triangle that has a file name of "image_unmoderated.gif". I wonder if the mods have put some kind of filter on images until approved? I'll message them.
In the mean time I've uploaded the images to Imgur and that seems to work.
