OPTIK TV streaming issue at my work home
AustinGreyson
Telus has made it virtually impossible for me to stream my OPTIK TV at my work home
I have a second home in Alberta where I stay for work. I have hooked up Telus internet and security, but not OPTIK TV, because I am supposed to be able to stream it anywhere, including at my work home. But I can't access the login pages while connected to my Telus internet, so I disconnect and use my mobile hotspot, (also Telus) login in, and reconnect to Wi-Fi and then I can stream, until I change sources or the screen saver comes on. Then I have to do the whole thing again.
The last time I forced it like that the entire wireless system crashed for my house and I couldn't log back on to the Wi-Fi at all on any of my devices. Even hard reset with the reset button wouldn't work. I ended up leaving it unplugged for 24 hours and it worked after that.
I've called tech support multiple times and their only suggestion is a new box.
Any thoughts/suggestions, besides switching my ISP to Shaw?
1 REPLY 1
WestCoasterBC
Did you not post about this the other week? Post seems oddly familiar under a different user name.. https://forum.telus.com/t5/Optik-TV/OPTIK-TV-streaming-issue-at-my-work-home/td-p/111949
What device are you using to stream optik tv on?
