New wireless box not working without ethernet cable
Reply
Blorchito
Connector
Hi. I can't get my new wireless TV box to work unless it's hardwired into the router. Do I also need to replace/upgrade my VIP5662W PVR to use wireless boxes?
Thanks.
WestCoasterBC
Follow this support document to sync with your T3200M here.
FuzzyLogic
Have you restarted the box without the wired connection? Hopefully it will prompt you for you Wi-Fi info.
Kalidgh
Connector
Make sure you have no ethernet connected to the Set Top Box.  Pull the power cord, count to5, plug it back in.  When prompted, push the WPS button on your gateway / modem.
It should just connect if in WIFI range
