Connecting wireless box in garage
Vance89
I am trying to connect a wireless box in my de-tached garage, but the signal isn’t strong enough to keep the box operating correctly. We have a Telus booster for our Wi-Fi. I know the boxes won’t run off that signal. I am unable to connect the box via Ethernet. Is there a way i can boost the signal from the t3200? Would just a non Telus Wi-Fi booster work? Would plugging a router into it help? Thanks
1 REPLY 1
Hero
This is a duplicate post. Your other one is in the correct sub forum, this one is not.
https://forum.telus.com/t5/Internet-Home-Phone/Connecting-wireless-box-in-garage/td-p/111674
