Audio cuts out on one channel, wireless box
Amethyst3
Coach
Optik TV, we have a DVR hard wired connected to one tv.  A wireless digital box connected to another tv. On one channel only, the sound intermittently cuts out and only on this tv.  If I tune to the same channel on the tv connected to the wired dvr, I notice the broadcast is not simultaneous, there is a delay of perhaps a couple of seconds or so, but the audio isn’t cutting out on that tv.  It’s channel 285.
The wireless box is a replacement for one that was frequently losing communication with the Optik service. (After trying all kinds of troubleshooting, a tech came and replaced the box.).
Is anyone else having issues with this channel via wireless digital?
1 REPLY 1
Welshk
Yes! Same issue with the same channel and set up. Not sure how to fix the issue - looking to wire the box, maybe that will help
