11-26-2020 01:51 AM
I don't notice because I am a PC/android guy, but my family is consistently complaining about losing/dropping wifi signal. They need to turn the device wifi on/off in order to get it back...what's with this? Why just the apple products? We have had the internet for a long time, then upgraded to bonded pairs to get better signal and, just recently, upgraded to the brand new modem and the 150 feed. We have had all the tech they have included two boost packs and still the same problem...I hoped the new modem would fix the issue, but no luck. Anyone have a fix for this?
11-26-2020 02:11 PM
There are reported wifi issues with the latest IOS:
More And More Users Report Wi-Fi Problems With iOS 14 - Macworld UK
You may also wish to investigate smart steering. If enabled you may wish to disable it and try connecting to a particular frequency (2.4 or 5 GHz). Here is some additional info:
Enable Smart Wi-Fi on Advanced Wi-Fi modem | TELUS Support
11-27-2020 03:58 PM
